Hi Guys!
New to arcGIS and trying to find out why my density map is being "squared off" like this. I've been testing out a bunch of different settings but to no avail.
Any tips?
Hi Megan, thanks for replying.
Yes, sorry, it's in Pro. I use the standard settings and population field "NONE"
You need to set your extents in the geoprocessing environment to be a larger extent. In Pro, it is in the tools Environments tab>Extent>Choose a layer that is larger than the dataset that you are running the tool on.
In ArcMap this is in the tools environment menu>processing extent> Extent. Choose a layer that is larger than the dataset that you are running the tool on.
That's it! Thanks a bunch
