Multipatch can't display in ArcGIS Pro but ArcScene can
2798
06-16-2016 01:45 AM
Nguyen_LeMinh_Nhy
I try using DIE to convert IFC to File GDB.
After converting, I can view the result (in multipatch) in ArcScene and ArcCatalog.
But when I bring it to ArcGIS Pro (Scene), I can't see it!
ArcScene
ArcGIS Pro
Thanks!
BruceHarold
Esri Frequent Contributor
Check your data has a spatial reference.
BruceHarold
Nguyen_LeMinh_Nhy
You are right!
This is data problem.
I found that my data still in millimeter after processing. I just need to scale it to meter then the data can display in ArcGIS Pro.
Thanks a lot!
