MS Access 32 bit via ArcPro
4311
6
04-12-2018 12:15 PM
BrianBulla
Honored Contributor
I'm trying to connect (through a custom tool developed via the current ArcPro SDK) to an MS Access 2003 database (32-bit) through ArcPro, but with no success.  I think it's because Pro is 64-bit, as I am able to connect to the same database through ArcMap 10.4 using a custom tool.
Can anyone confirm what I think is happening?  Is there a workaround??
BrianBulla
Honored Contributor
So for anyone interested, here is a workaround for connecting to a 32-bit MS Access database file through ArcPro.  Of course, this is for someone having the same system issue as I am having, which is installing both 32 and 64 bit MS Office drivers at the same time.
How to install 64-bit Microsoft Database Drivers alongside 32-bit Microsoft Office | AutoCAD | Autod...
BalajiVeera
64-bit SQL Server Native Client (or) 64-bit SQL Server ODBC Driver (if Windows 7)
KoryKramer
Esri Esteemed Contributor
BrianBulla
Honored Contributor
I read the article.  So what does this mean for .mdb files.  Will I not be able to connect to any of our .mdb databases through ArcPro??
What I am trying to do is create an OleDBConnection through some .NET code to connect to the database.  From everything I have read, it's more of a Microsoft/OS issue than an esri ArcPro issue.  Through VisualStudio (32 bit) I can connect to it, but through ArcPro (64 bit) I cannot.  My system (Windows 7 64 bit) does not seem to want to let me install the 64-bit Office drivers.  I think I have 32 bit office installed right now??
PGDB support is another issue, but just being able to access a regular Access database I don't think would be an esri issue.  I don't think any 64-bit application on my machine would be able to access this database, not just ArcPro.
Of course, I could be totally wrong as I don't have a great understanding of the issues.
Anyways, I'm still trying to figure this out.  Installing/uninstalling drivers from here:  Download Microsoft Access Database Engine 2010 Redistributable from Official Microsoft Download Cent... , but no luck as of yet.
RobertBorchert
Honored Contributor
That is correct. You can no longer use MS Access compatible databases with Pro.
There are a lot of reasons why I am not using Pro and this one is huge.
TedKowal
Honored Contributor
Also vote here for MS Access support in Pro ..  Enable ArcGIS Pro to access ESRI Personal Geodatabases
BrianBulla
Honored Contributor
