MRsid in arcgis pro
15063
9
08-20-2019 08:18 AM
AntonyLopez
Pretty straight forward, I am not a power user, but is there a way to get .sid files to work on ArcGIS Pro, or is it only possible in ArcMap?
BruceHarold
Esri Frequent Contributor
Hi, Data Interoperability extension can read Lizardtech MrSID.  The workflow would be to convert the data to a supported raster dataset.
BruceHarold
GregNewkirk
How do you use Data Interoperability to convert MrSID files? It is not listed in the FME Reader Gallery.
GregNewkirk
I found it in the Data Inspector. It did not appear in the Quick Import Tool.
DanPatterson_Retired
strange, since according to
Raster file formats—ArcGIS Pro | ArcGIS Desktop
they should be able to be read
Multiresolution Seamless Image Database (MrSID)
A proprietary compression technique especially for maintaining the quality of large images. Allows for a high compression ratio and fast access to large amounts of data at any scale. The MrSID Encoder is developed and supported by LizardTech, Inc.LizardTech website
Supports generations 2, 3, and 4.
sSingle file—extension *.sid
World file—extension *.sdw
Read-only
8-, and 16-bit unsigned integer
Yes
Generation 2 and generation 3—limited to 1 or 3 bands
Generation 4—unlimited
Wavelet (lossy)
No
anything special? are you adding them to an empty map?
LeonS
I was able to my SID file into a Pro map. No extension needed.
GregNewkirk
When I upgraded from 2.4 to 2.6, ArcGIS Pro stopped reading my MrSID files. I removed and then re-added them after seeing your comment. Now they draw. Thanks.
GregNewkirk
JerryBartz
Confirming that ArcPro 3.1 reads a .sid file directly.
AntonyLopez
That's just what I needed! the Data Interoperability extension! Thank you all!
