Mosaic dataset tools not working properly in ArcGIS pro?
7918
12
07-26-2016 01:02 PM
SubuSwaminathan1
Mosaic dataset tools not working properly in ArcGIS pro? having trouble with Add rasters, build overviews etc. data corruption, slowness are some symtoms
Have also seen Pro freeze up and corrupt the mosaic dataset.
Anybody else seeing these kind of issues?
JamieDrisdelle
We are noticing somewhat slow behavior when adding several rasters from a network location using this control. It was validating every record it was adding to the table control. Didn't really notice it so much when adding rasters locally (i tried 500) but that could still be the case for you depending on hardware configuration. We will have this fixed for the next release. Sorry for the inconvenience.
DavidWasserman
Can you verify if there are any raster environment settings that break Add Raster to Mosaic? I have had some issues with raster masks/processings extents and was curious if this is a known issue. What settings are known to be troublesome?
David Wasserman, AICP
XanderBakker
Esri Esteemed Contributor
There is a blog with some great information here: Troubleshooting Performance Issues in ArcGIS Pro | ArcGIS Blog
Especially the "Shift-E" and ArcMon can help to see what is happening with the performance of ArcGIS Pro.
