Mosaic Dataset created in ArcMap can't be opened in Pro
1021
11-23-2023 10:43 AM
ConnorPatrickDennehy
So I am finally starting to migrate from Desktop to Pro and immediately am facing the following issue: my mosaic datasets, created in ArcMap, cannot be opened in an .aptx. The error message reads "Failed to add data, unsupported data type". I'm just trying to drag it in from a folder connection, which also contains the overviews and raw files.
I would think there must be a simple solution/explanation for this, though I haven't been able to find one thus far.
David_McRitchie
Hey Connor I came across the following support article that discusses differences in naming restrictions between ArcMap and ArcGIS Pro which might be causing this on your system.
Hope that helps,
David
Esri UK -Technical Support Analyst
