ModelBuilder resets tools to 'ready-to-run' state
14224
32
12-27-2021 07:27 AM
ChrisD
Hello!
When working with ModelBuilder, tools that I have already run and are in the 'has-been-run' state are very often reset to 'ready-to-run' when I add data to the model or make other changes to the workflow that are not upstream of the change and thus should not have any affect on the reset model elements. It really turns models into a mess because rather than re-running every time a tool resets, I end up adding the data from the previously run tool into the model so I'm not constantly re-running my workflows when this resetting happens. Any help in remedying this would be much appreciated.
Thanks!
Chris
Tags (1)
ShitijMehta
Thanks for reporting this. Will test this case and comment again. We fixed two cases where the tool would rerun in 3.2.
CStarbirdDudek
It's been a year since there's been any activity on this thread, but I'm an avid Model Builder fan and continue to think that it's been broken since day-one on ArcGIS Pro. I'm running version 3.3.2 and continue to see unnecessary re-runs of portions of my model. Has there been any progress on this front? Model builder is an essential tool in our workflow. Thanks for your help.
ChrisD
Honestly not sure what the status is from ESRI's perspective. Hopefully they'll weigh in here. Certainly not fixed by any means. Seems a little better than it used to be, but I still have to do a lot of unnecessary reruns as well.
