ModelBuilder Failed to Create New Model
2555
01-23-2024 01:06 PM
Labels (3)
SpencerMauch
I am trying to use ModelBuilder in Arc GIS Pro.  I have used it successfully in times past, however, it is now failing.  Whenever I click ModelBuilder on any project, I get the message found below "Failed to create new model". Any suggestions of what might be the issue?
DanPatterson
Pro version?
BUG-000158118 for ArcGIS Pro (esri.com)
more details regarding your environment would be useful
... sort of retired...
SpencerMauch
Hi Dan,
Thank you for your help, my Pro Version is 3.1.2.
MattWilkie3
I get this with ArcGIS Pro 3.3 and project stored on a mapped network drive. I get the same error when trying to create a new toolbox (.atbx). I can however create new python toolbox (.pyt).
If work from a project on C: drive I can create all 3 - atbx, pyt, and model.
Adding a C: folder to the network project and creating inside that is not a workaround.
