Model Builder - Scheduled Task with Secured Service
756
09-14-2024 01:12 PM
MeleKoneya
Hello,
I am am running a simple model that uses a secured feature layer and exports its features to GeoJson.
I can run the model in ArcGIS Pro Modelbuilder and everything works as expected.
If I convert that model to run as a scheduled task, nothing happens.   No errors either.
I have access to the secured feature layer via my AD login so I thought maybe I needed to run the task with my credentials but still no luck.
Do I need to add reference to my ArcGIS Pro project to the script knows how to find the layer?
Any help is appreciated.
Thank you,
Mele
JakeSkinner
Esri Esteemed Contributor
@MeleKoneya I would recommend exporting the Model to a python script.  Then, in the script, add the following line:
arcpy.SignInToPortal("https://webadaptorhost.domain.com/webadaptorname",
                     'username@DOMAIN', 'password')
 If the script executes successfully, you can easily schedule this as well.  Check out the document here.
