Model Builder Schedule Not Working
6138
10
09-06-2022 03:27 PM
Michael_VanHatten
I have been having issues with Model builder in ArcPro. It seems not matter how simple or how many times I try recreating models they will never run on the scheduler function that is advertise within Pro. It has become a very frustrating issue and I am wondering if I am the only one? For some context I am using Arcpro 3.0.0 I know there is an update available but this started before 3.0.0 and even after I updated it still exists.
I have created very simple models that join two features, select by and attribute, calculate a field, then un join the features. Nothing fancy. All my models work when I manually run them without any issues. When I try to schedule the model I get error code 000852, which says that a field can not be added. I have tried asking ESRI tech support but they had very little helpful information, after hours on the phone with them I gave up for lack of progress but I am back again with a new model and new data running into the same issue.
Has anyone experienced this? Has anyone found a solution? Any ideas would be appreciated.
Thanks
DanPatterson
MVP Esteemed Contributor
The video link in the help didn't reveal anything that differs from your scheduling process?
Schedule a model—ArcGIS Pro | Documentation
... sort of retired...
Michael_VanHatten
That is exactly how I am scheduling the model, mine just doesn't run after about a minute or two after the time set.
JonathanWhite1
I think I found a solution to an ongoing issue. For some reason when you schedule a model it partly saves at the time you schedule. If you go back and edit the model and save it doesn't fully replace the previous save that task scheduler has.  My solution for this obvious bug is to delete the schedule completely then save your model then reschedule. That is what worked for me.
CCWeedcontrol
I have had this issue with almost every model I have created and "tried" to schedule.
I have done what you stated multiple times, over and over and still some scheduled models don't work.
In my opinion Pro is so JUNKY it has so much flaws. Its hard to get any work done.
Jim
Hi Michael,
Did you ever find a solution to this question? I am running into the same problem. When I run my model manually everything works properly, however, any schedule I create will not run. Thanks!
LindseyGreidanus
I am having the same issue... model runs manually but when scheduled will not run. Its giving me an ERROR 000358: Invalid expression for the very first step, but I don't think there is anything wrong with the expression.
KaraUtter2
On one server, my schedule doesn't even run. There is no error message. It successfully schedules itself and saves and regardless of whether ArcGIS Pro is active and running or not, it just doesn't run. I have tried setting it to run once and I have tried setting it to run daily. It just doesn't run. What is the ongoing issue with this?
On my personal computer, I keep getting the below error. This runs perfectly when run manually.
New Model_03272024_1112AM
Parameters
Parcels_BackUp_Laurie .\ValleyCounty_Parcels.gdb\Parcels_BackUp_Laurie
Parcels_BackUp_Kathy .\ValleyCounty_Parcels.gdb\Parcels_BackUp_Kathy
Messages
Start Time: Wednesday, March 27, 2024 11:15:11 AM
Executing (Copy): Copy C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_Copy2_Dec23 C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\ParcelsBackUp_Laurie FeatureClass #
Start Time: Wednesday, March 27, 2024 11:15:17 AM
Succeeded at Wednesday, March 27, 2024 11:15:23 AM (Elapsed Time: 5.43 seconds)
Executing (Created Features from Laurie): CreateFeatLaur C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records
Start Time: Wednesday, March 27, 2024 11:15:23 AM
Succeeded at Wednesday, March 27, 2024 11:15:24 AM (Elapsed Time: 1.30 seconds)
Executing (Edited Features from Laurie): EditedFeatLaur C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records
Start Time: Wednesday, March 27, 2024 11:15:25 AM
Succeeded at Wednesday, March 27, 2024 11:15:26 AM (Elapsed Time: 1.40 seconds)
Executing (Merge): Merge C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records;C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates "PARCELNO "PARCELNO" true true false 30 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,PARCELNO,0,29,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,PARCELNO,0,29;LOT "LOT" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,LOT,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,LOT,0,4;BLOCK "BLOCK" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,BLOCK,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,BLOCK,0,4;PARENT_PAR "PARENT_PAR" true true false 254 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,PARENT_PAR,0,253,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,PARENT_PAR,0,253;Date "Date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,Date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,Date,-1,-1;Change_typ "Change_typ" true true false 50 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,Change_typ,0,49,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,Change_typ,0,49;LRSNum "LRSNum" true true false 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,LRSNum,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,LRSNum,-1,-1;PIN "PIN" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,PIN,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,PIN,0,254;GlobalID "GlobalID" false false true 38 GlobalID 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,GlobalID,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,GlobalID,-1,-1;created_user "created_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,created_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,created_user,0,254;created_date "created_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,created_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,created_date,-1,-1;last_edited_user "last_edited_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,last_edited_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,last_edited_user,0,254;last_edited_date "last_edited_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,last_edited_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,last_edited_date,-1,-1;Shape_Length "Shape_Length" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,Shape_Length,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,Shape_Length,-1,-1;Shape_Area "Shape_Area" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_created_records,Shape_Area,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_edited_records,Shape_Area,-1,-1" NO_SOURCE_INFO
Start Time: Wednesday, March 27, 2024 11:15:26 AM
WARNING 000117: Warning empty output generated.
Succeeded at Wednesday, March 27, 2024 11:15:27 AM (Elapsed Time: 0.88 seconds)
Executing (Copy (3)): Copy C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_CopyDec23 C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\ParcelsBackUp_Kathy FeatureClass #
Start Time: Wednesday, March 27, 2024 11:15:27 AM
Succeeded at Wednesday, March 27, 2024 11:15:30 AM (Elapsed Time: 2.90 seconds)
Executing (Created Features from Kathy): CreateFeatKathy C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records
Start Time: Wednesday, March 27, 2024 11:15:30 AM
Succeeded at Wednesday, March 27, 2024 11:15:32 AM (Elapsed Time: 1.28 seconds)
Executing (Edited Features from Kathy): EditedFeatKathy C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records
Start Time: Wednesday, March 27, 2024 11:15:32 AM
Succeeded at Wednesday, March 27, 2024 11:15:33 AM (Elapsed Time: 1.19 seconds)
Executing (Merge (2)): Merge C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records;C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates "PARCELNO "PARCELNO" true true false 30 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,PARCELNO,0,29,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,PARCELNO,0,29;LOT "LOT" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,LOT,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,LOT,0,4;BLOCK "BLOCK" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,BLOCK,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,BLOCK,0,4;PARENT_PAR "PARENT_PAR" true true false 254 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,PARENT_PAR,0,253,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,PARENT_PAR,0,253;Date "Date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,Date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,Date,-1,-1;Change_typ "Change_typ" true true false 50 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,Change_typ,0,49,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,Change_typ,0,49;LRSNum "LRSNum" true true false 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,LRSNum,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,LRSNum,-1,-1;PIN "PIN" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,PIN,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,PIN,0,254;GlobalID "GlobalID" false false true 38 GlobalID 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,GlobalID,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,GlobalID,-1,-1;created_user "created_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,created_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,created_user,0,254;created_date "created_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,created_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,created_date,-1,-1;last_edited_user "last_edited_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,last_edited_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,last_edited_user,0,254;last_edited_date "last_edited_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,last_edited_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,last_edited_date,-1,-1;Shape_Length "Shape_Length" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,Shape_Length,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,Shape_Length,-1,-1;Shape_Area "Shape_Area" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_created_records,Shape_Area,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_edited_records,Shape_Area,-1,-1" NO_SOURCE_INFO
Start Time: Wednesday, March 27, 2024 11:15:33 AM
Succeeded at Wednesday, March 27, 2024 11:15:34 AM (Elapsed Time: 0.83 seconds)
Executing (Merge all Update Records): Merge C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates;C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_MergedUpdateRecords "PARCELNO "PARCELNO" true true false 30 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,PARCELNO,0,29,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,PARCELNO,0,29;LOT "LOT" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,LOT,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,LOT,0,4;BLOCK "BLOCK" true true false 5 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,BLOCK,0,4,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,BLOCK,0,4;PARENT_PAR "PARENT_PAR" true true false 254 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,PARENT_PAR,0,253,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,PARENT_PAR,0,253;Date "Date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,Date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,Date,-1,-1;Change_typ "Change_typ" true true false 50 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,Change_typ,0,49,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,Change_typ,0,49;LRSNum "LRSNum" true true false 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,LRSNum,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,LRSNum,-1,-1;PIN "PIN" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,PIN,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,PIN,0,254;GlobalID "GlobalID" false false true 38 GlobalID 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,GlobalID,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,GlobalID,-1,-1;created_user "created_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,created_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,created_user,0,254;created_date "created_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,created_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,created_date,-1,-1;last_edited_user "last_edited_user" true true false 255 Text 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,last_edited_user,0,254,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,last_edited_user,0,254;last_edited_date "last_edited_date" true true false 8 Date 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,last_edited_date,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,last_edited_date,-1,-1;Shape_Length "Shape_Length" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,Shape_Length,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,Shape_Length,-1,-1;Shape_Area "Shape_Area" false true true 8 Double 0 0,First,#,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Laurie_AllUpdates,Shape_Area,-1,-1,C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Kathy_AllUpdates,Shape_Area,-1,-1" NO_SOURCE_INFO
Start Time: Wednesday, March 27, 2024 11:15:34 AM
Succeeded at Wednesday, March 27, 2024 11:15:35 AM (Elapsed Time: 0.89 seconds)
Executing (Copy (2)): Copy C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_Original C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_Original_BackUp FeatureClass #
Start Time: Wednesday, March 27, 2024 11:15:35 AM
Succeeded at Wednesday, March 27, 2024 11:15:39 AM (Elapsed Time: 3.34 seconds)
Executing (Join Original and Update by Parcel Number): AddJoin Parcels_Original PARCELNO C:\Users\kcoll\OneDrive\Documents\ArcGIS\Projects\ValleyCounty_Parcels\ValleyCounty_Parcels.gdb\Parcels_MergedUpdateRecords PARCELNO KEEP_ALL NO_INDEX_JOIN_FIELDS NO_REBUILD_INDEX
Start Time: Wednesday, March 27, 2024 11:15:39 AM
Succeeded at Wednesday, March 27, 2024 11:15:39 AM (Elapsed Time: 0.26 seconds)
Executing (Select Non-Null Update-Date Records): SelectLayerByAttribute Parcels_Original "New selection" "Parcels_MergedUpdateRecords.PARCELNO IS NOT NULL" #
Succeeded at Wednesday, March 27, 2024 11:15:40 AM (Elapsed Time: 0.49 seconds)
Executing (Remove Join): RemoveJoin Parcels_Original Parcels_MergedUpdateRecords
Start Time: Wednesday, March 27, 2024 11:15:40 AM
ERROR 000622: Failed to execute (RemoveJoin). Parameters are not valid.
ERROR 000800: The value is not a member of .
Failed to execute (Remove Join).
Failed at Wednesday, March 27, 2024 11:15:40 AM (Elapsed Time: 0.05 seconds)
Failed to execute (NewModel).
Failed at Wednesday, March 27, 2024 11:15:42 AM (Elapsed Time: 31.57 seconds)
JustinH
Also running into this same issue in ArcGIS pro 3.3.1
Laura
by MVP Regular Contributor
I am also facing this issue. Only runs the first time when I schedule it.
