Model builder - ArcgisPRO strange behaviour
1349
05-14-2024 11:28 PM
MihaRobar
Has anyone experience, that model builder runs in edit mode/diagram preview, if runned as normal - in tool, makes empty outputs.
I have also noticed, that if runed from diagram it adds data to map if runed from tool view, add to map functionality failed.
Is there any reason/solution?
Miha
GeeteshSingh07
Hi @MihaRobar, hope this helps.
If you're talking about intermediate data from the process, then it is expected behavior.
  • When a model is run from the Geoprocessing pane, the outputs marked as Intermediate Data are deleted automatically.
  • When a model is run within ModelBuilder, the outputs marked as Intermediate Data are deleted by clicking the Intermediate button on the ModelBuilder ribbon.
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/modelbuilder/intermediate-data....
As intermediate data is deleted, therefore, it can't be added to map.
If you want to add final output of model to map: Check this option settings/options-
Best Regards,
Geetesh
[email protected]
MihaRobar
everything is set as desrcibed. Can you check my workflow and test?
Again, i am getting right results from the editmode and running the model.
When running as geoprocessing tool - dubleclik on the model it runs and creates empty fetureclass of parcels. Tiff is created  but not added to a basemap (for test, you can release tiff cliping). Due to that i am unable to sherr the tool.
Thanks.
Miha
MihaRobar
and the workflow...
