model builder arcgis pro - select, zoom, label parcels
2716
07-22-2019 03:51 PM
RaeRife
Hello:
I'm new to model builder and python, but would like to know if it's possibly to customize a repeated workflow. I enter the parcel number, zoom to the selected parcel, create a layer or export it to a feature, outline it in bold 3 pt red and label it in white with the Assessor Number and the Acres. This is what I've got so far in model builder but I don't know how to make it zoom to the parcel and do the rest of the steps. Also, I need to be able to change the parcel number each time a new customer enters.
by Anonymous User
Not applicable
Maybe take a look at:
   https://community.esri.com/thread/8396
Unfortunately the code isn't Arcpy.mp; it's the older Arcpy.mapping stuff so you may have to update that but it's probably a good starting point
RaeRife
Thank you Adam. I don't even know how to script in Python, but I'm up for learning.
Rae
DrewFlater
Doing interactive steps as you described is not the purpose of ModelBuilder, which is for automating geoprocessing workflows.
Everything you described could be encapsulated in a Task instead that gives more guidance to do each of the steps. This will not require any coding and provides an easy-to-use guide for creating reproducible  workflows.
Learn more about ArcGIS Pro Tasks: https://pro.arcgis.com/en/pro-app/help/tasks/whatistask.htm
And here's a great workshop from User Conference about Tasks: https://www.youtube.com/watch?v=R4GEFwMIu-M
