ArcGIS Pro 3.1.1
When I create a mobile GDB spatial database view, I can't seem to open the attribute table directly using 'Open Table' in the Catalog pane.
Steps:
I don't have that problem when using 'Open Table' in Catalog on a feature class. Nor do I have that problem with non-spatial tables or non-spatial views. I only have the problem with spatial views.
Is that a bug?
Solved! Go to Solution.
Support has confirmed it's a bug:
Esri Case 03314538 - Mobile GDB spatial database view — Can't open attribute table directly using "Open Table" in Catalog
BUG-000157475: Cannot open table from the Catalog pane for a spatial view found in a mobile geodatabase.
I also determined there is a workaround of sorts:
In other words: spatial view —> non-spatial view —> spatial view fixes the view.
