MMPK Definition Query Not Working
1085
05-07-2019 05:44 AM
RyanUthoff
MVP Regular Contributor
I am having an issue with creating mobile map packages with a definition query applied. I have a single layer I am trying to create a MMPK from. I set up a definition query based on a date field where anything before a certain date is filtered out. After applying the definition query, I have 4,339 records. But when I create a MMPK from that layer, the MMPK has 0 records. If I remove the definition query from the layer, then all of the records appear in the MMPK.
I am able to replicate this behavior when reading the MMPK in both ArcGIS Pro and Explorer.
Are definition query's not compatible with MMPK's?
Jeremy_Z
I know this is an older post, but I'm running into this with a new set of layers I added to a project. The layers export, but there is no data in them whatsoever and there should be 20 to 30 thousand features.
I'm attempting another export with this def query turned off right now, and was thinking about trying to recreate these filters through the symbology and grouping, did you have any luck with a work around?
GIS - Getting it Surveyed is too expensive.
