Missing polygon curves after a delete and append?
702
02-10-2023 07:14 AM
Labels (3)
gableh
Hello -
I have created a model that simply deletes data from a feature, then appends data from another. It runs every night.
Today, we have found the issue that curves in the original data are being converted to lines. Has anybody else had this issue? Is there an easy solution that I may be missing?
Thanks!
DanPatterson
MVP Esteemed Contributor
Featureclass in a file geodatabase is the destination?  What is the source?
have you set this in the append tool's environments?
Maintain Curve Segments (Environment setting)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
MichaelVolz
Dan:
Was this not an issue with models/scripts created in ArcMap?
gableh
Oh shoot - that's my answer. Thank you!
