Minimum scale in Map Series
1839
10-17-2023 02:48 PM
BinhLe
I have a Map Series where the maps scale varies from 200 to 12000 .  I want to make the minimum scale 1:1000. Is there a way to do this in ArcGIS Pro?
AubriOtis
Yes! You can set the round scale to nearest 1000 and it should round it up.
Cheers,
Aubri
BinhLe
Hi Aubri,
This works for some. The problem is that it rounds down. I have a 1400 scale map that gets round down to 1000, then it is cut off. I current change the minimum scale several times to get all my maps to export correctly
Binh
AubriOtis
I see, that's frustrating. In the upcoming release of ArcGIS Pro 3.2 a change was made so those values always round up. I think that will make this more effective for your scenario.
Cheers,
Aubri
