Tools automatically populate tool parameters with previously used values, which tools?
2442
05-26-2023 03:56 PM
Labels (2)
by Anonymous User
Not applicable
Hello all,
I'm using 3.1.1.
In the New at 3.0 info https://pro.arcgis.com/en/pro-app/3.0/get-started/whats-new-in-arcgis-pro.htm under Productivity it states: "Certain tools that you open from the ribbon, toolbars, and other locations automatically populate tool parameters with previously used values."
Which "Certain tools" are these?
I really needed this functionality this week with the Map Ribbon - Select by Location tool. Alas, Pro never remembered the Selecting Features value and I had to reset it every time. Probably around 50 times, I would estimate.
Help!
Thank you.
DanPatterson
MVP Esteemed Contributor
try the History tab, select something from history, right-click, open...  I use it often
There is loads of other things you can do with History... just a right-click away
... sort of retired...
by Anonymous User
Not applicable
@DanPatterson ooh you're right. I always forget about the History tab. I have it open now and I tested it for this work flow and it works. I'll try to retrain my brain - thank you for the tip.
AndreaB_
OP here, re-subscribing with new Community User name.
