Measuring the distance between one central point and 900 surrounding points
1538
02-04-2021 03:42 PM
GPWater
I am using ArcGIS Pro 2.4.0
Hello! I am somewhat new to GIS software.
I have one centrally located point on a map. I would like to measure the distance between that one central point and about 950 surrounding points with the goal of exporting each point and its distance from the central point into one excel file. Is there a fast way to do this without having to manually measure each point with the "Measure" tool?
Thanks!
Robert_LeClair
Esri Esteemed Contributor
I'm thinking the Generate Near Table geoprocessing tool will do the trick.  It rights an output table with the and provides the XY of the point, the XY of each of the 950 points, the angle and distance.
Robert_LeClair
DanPatterson
MVP Esteemed Contributor
Just make sure your central point is a separate layer
... sort of retired...
GPWater
Yes, using the Generate Near Table tool worked great! Thank you so much.
Robert_LeClair
Excellent!  If you feel my answer is the correct answer, then please mark "Accept as Solution" to close this thread.  All the best!
