HEAT INDEX ANALYSIS IN THE LA LIBERTAD-CHICAMA VALLEY REGION 2027
Description: Data used: - NASA raster satellite (Land Stands 8 and 9) - Fire hotspots in the La Libertad region, provided by NASA. - Departmental map of La Libertad (created by myself) - Areas with high temperature, low vegetation, and high population density are the most vulnerable to extreme heat (intense red zones). Immediate tree planting is recommended in these areas to balance the extreme high temperature. Green and yellow zones represent areas with average and low temperatures.
FIRE ANALYSIS IN THE LA LIBERTAD REGION - CHICAMA VALLEY ZONE 2027 USING THE MAX ENT-ARCGIS PRO METHOD-PART 1
FIRE ANALYSIS IN THE LA LIBERTAD REGION - CHICAMA VALLEY ZONE 2027 USING THE MAX ENT-ARCGIS PRO METHOD-PART 2
3D FORECAST ANALYSIS OF LA LIBERTAD - CHICAMA VALLEY FLOOD ZONE (RED ZONES = DANGER OF FLOOD RISK, WHITE ZONES = SAFE)
LEYEND OF 3D FORECAST ANALYSIS OF LA LIBERTAD - CHICAMA VALLEY FLOOD ZONE (RED ZONES = DANGER OF FLOOD RISK, WHITE ZONES = SAFE)
