Map to KML process Crashing Application
1561
08-23-2024 12:32 PM
DustinCokely
I am attempting to generate a Google Earth map using the Map to KML conversion tool, however the process will quickly fail, and crash the application.
  • All layers, including the map, are utilizing the WGS 1984 Coordinate System
  • This does not occur on a newly created project, only previously saved/created projects.
  • I am not provided an error code.
  • When the application is reopened, my work has been saved, and I am not asked if I would like to start from my last save, or a backup.
  • This issue did not occur two days ago when completing similar tasks within the same projects I am experiencing issues with today.
Ed_
by MVP Regular Contributor
could be a bug
  • may be try clearing the project cache under Project > Options >Display> Scroll to the bottom and click clear cache
  • may be try restarting your computer
  • may be trying updating Pro if it's not on 3.3 (latest)
  • may be try reinstalling Pro
  • may be try opening those projects in Pro on another computer and see if the crash happens again.
Question | Analyze | Visualize
