Map Tips for Lidar Point Cloud data
336
05-27-2026 01:40 PM
FSD_Main
I have a layer that was set to show Map Tips for Lidar bare earth points, but seems now I can't get those map tips to work and when I go into that layer's properties, to display, it does not give the option to turn on Map tips. If anyone has any insight on how to get these back in ArcPro 3.6 I'd appreciate any advice.
Thank you
Robert_LeClair
Esri Esteemed Contributor
In ArcGIS Pro, the Map Tips toggle only appears for layer types that support attribute-based map tips (typically feature layers). For LiDAR point cloud layers (for example, a LAS Dataset layer or a Point Cloud Scene Layer (.slpk)), it’s normal to not see a Map Tips option in Layer Properties, because those layers are driven more by filtering/symbology than per-point attribute popups.  If you need to see the attributes for a single point, click the Map tab->Explore and click on a *.las point.
