Map text to coordinate layer
371
05-14-2026 02:14 AM
Labels (2)
AdamNicholson
Hi all,
I am looking to use OS maps to make a layer. Can arcgis pro search the basemap image for "swallow hole" for example, and then create a shapefile with coords at every instance of those words on the  map?
I want to use it to make a rough swallowhole location layer for later groundtruthing.
Any help would be super appreciated, thanks
Linoom
Robert_LeClair
Esri Esteemed Contributor
No—there aren’t any Esri basemaps in ArcGIS Pro whose label text is keyword-searchable. Basemaps are for visualization and aren’t searchable by attributes, so you can’t search their drawn text/labels.
If you need keyword search, the text must come from operational feature layers (searchable attributes) or a locator (for place-name/address search). In this tutorial below, it mentions that users can’t “search for features in the basemap” and that interactive/searchable layers should be in the operational map: Tutorial: Create an offline map—ArcGIS Pro.
