Map templates for ArcGIS Pro
2343
09-12-2025 02:13 PM
SelfIntersectingPolygon
I am looking for a sample/example ArcGIS Pro map that has symbology, labels, etc. to get started building a map to use in a map book. There are so many scale levels to set, etc. that I was hoping I would not have to start from scratch. I think Esri used to provide MXD documents for maps like the Street Map back in the ArcMap days. Is there something like that for ArcGIS Pro? Or, are the ArcMap documents still available? What is a good resource to consult for these? Again, I am not looking for an online map, but an aprx document that I can use to get started create all the symbology for a map book.
I have downloaded a solution for a public safety map book but it basically just has a basemap with some address points and streets. Perhaps that's the way to go now instead of building a whole map from scratch?
RClavero
Hello @SelfIntersectingPolygon, I would have a look at Learn ArcGIS*. There is see, for example, this tutorial in which you can download an ArcGIS Pro project package (.ppkx). And there might be other project packages available maybe more suitable for your end goal within the available list of resources.
*https://learn.arcgis.com/en/gallery/#?p=arcgispro
Todd_Metzler
Have an ArcGIS Online (AGOL) Organizational or personal use account or ArcGIS Enterprise?  Then many of the the Esri out of the box ArcGIS Solutions include ArcGIS Pro Project templates for different use cases.
