Map Properties, Clip Layers, Exclude layers from clipping menu
395
09-01-2025 07:32 AM
SallyEdwards
Hi does anyone know when using ArcGIS Pro Desktop, Clip Layers in the Map Properties is there a way to save the list of Exclude layers?
instead of having to select them every single time you create a Map Clip.
It appears to reset to nothing selected each time you do it, which is annoying when you always want certain basemap layers to be excluded from the clip.
