Map Package older version
1952
04-24-2020 04:20 AM
María_JoséSoldado
Can we save a Map Package in an older ArcGIS version?
I mean, I would like that someone with ArcGIS 10.4 could be able to open the Map Package that I send him built with ArcGIS 10.7. Is this possible?
Thanks!
George_Thompson
Esri Notable Contributor
It looks like this is possible in the GP tool:
version
[version,...]
(Optional)
Specifies the version of the geodatabases that will be created in the resulting package. Specifying a version allows packages to be shared with previous versions of ArcGIS and supports backward compatibility.
A package saved to a previous version may lose properties available only in the newer version.
  • ALL — Package will contain geodatabases and a map document compatible with all versions (10.0 and later).
  • CURRENT — Package will contain geodatabases and a map document compatible with the version of the current release.
  • 10.5 —Package will contain geodatabases and a map document compatible with version 10.5.
  • 10.4 —Package will contain geodatabases and a map document compatible with version 10.4.
  • 10.3 —Package will contain geodatabases and a map document compatible with version 10.3.
  • 10.2 —Package will contain geodatabases and a map document compatible with version 10.2.
  • 10.1 —Package will contain geodatabases and a map document compatible with version 10.1.
  • 10 —Package will contain geodatabases and a map document compatible with version 10.0.
Package Map—Help | Documentation
--- George T.
María_JoséSoldado
Thanks!!!!
