Map Layout Legend Contents - Dynamic Thematic Map Series Filtering?
905
5
01-27-2026 12:19 PM
JasperRomero
Hello Community,
Hoping for some input on whether this can be accomplished by currently available means, and if not, whether folks know of an Idea that has already been submitted.
I recently used the Thematic Map Series workflow for making layouts for the first time, so I had several Radio Layer Groups in my Map Contents with multiple copies of the same source layers. In general, each map showed different subsets of the same source data. While the Legend Element configuration options to only show populated layers and only show visible layers in the legend worked as expected, it was very unwieldy to try to manually configure Legend order in the Drawing Order contents with several dozen layers, many of which shared names.
Is there any way to get the Drawing Order Legend Contents to only show the layers that are in the currently toggled radio group? This would be a huge quality of life improvement for making Map series.
Thanks in advance for any inputs or suggestions!
Tags (3)
VenkataKondepati
Honored Contributor
As per my understanding, there’s no built-in way for the Legend Drawing Order pane to automatically filter down to only the layers in the currently active radio group
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
AlfredBaldenweck
MVP Frequent Contributor
JasperRomero
@AlfredBaldenweck it removes layers from the Legend element on the Layout - what I am asking about here is having the Legend Contents (lefthand panel, default sorted by Drawing Order) dynamically reflect only the layers present in the current Map in a Series. When making a Series of several maps that show different subsets of the same source layers, the Legend Contents gets difficult to navigate and organize pretty quickly.
I am stuck with Pro 3.4.3 for the foreseeable future, so maybe this is addressed in the current release, but I haven't been able to find documentation of that yet.
AlfredBaldenweck
Oh, I understand. That is a toughy. Best I could do is just make multiple legends. If you make an Idea for this I'd upvote it.
JasperRomero
Thanks, will keep this thread posted if I make an Idea. Even being able to set up Group Layers in Legend Contents the way we can in Map Contents (or better yet, just pulling Groups from Map Contents to Legend Contents) would be great.
