Map graphics suddenly unselectable
4570
10
05-02-2023 01:22 PM
wayfaringrob
Honored Contributor
Hi all, I am curious what the workaround is to a map graphics layer becoming unselectable. I have two graphics layers in my map, one for labels and one containing a white polygon for some layout trickery. However, I'm no longer able to select that polygon or edit its vertices.
I can't click it with the graphic select tool (even when Target Layer is set to that one), and Select All only picks up my road labels:
Graphics also have no TOC/layers pane for selection that way as far as I know, but I know it's in that layer because it turns off when I uncheck its box:
I'm stumped but wouldn't be surprised if this is a bug. Is it possible for graphics layers to be locked? I've cleared my cache, have tried making copies of the layer, map, and even exporting as a .lyrx and adding back to the map -- no luck. Looking for suggestions if others have run into this, thanks.
wayfaringrob
Honored Contributor
Happened again in another project created in Pro 3.1.1. Must be a bug.
wayfaringrob
Honored Contributor
Workaround: Right click the feature. You get a context menu of course, but at least it selects. However, still no remedy for 'select all' or multi-select with dragging or otherwise.
Paul_C_Anderson
Thanks for the tip on the right click- I was pulling my hair out trying to deal with this.
ODWC_GIS
Thank Deus!  I thought I was going crazy!
v3.2
NancyBellegarde1
Thank you! this was driving me crazy.
RaelynCaldwell1
THANK YOU!!!
SteveIrving
Here we go again... as ESRI continues to break ArcMap and i continue to 'try' to be productive in 'pro', something like this gobbles up unnecessary time.  Is this really still broken?  has there been any explanation?
I, too, discovered the 'workaround' but that eliminates all of the select by rect, poly, line, etc... functionality.  and of course, it is impossible to select more than one item at a time like this.  Is there an accidentally tripped setting here somewhere????
in what way is this 'pro' behavior????
ZeMadmapper
Thanks for the tip on the right-click @wayfaringrob . I was just about to go bananas. I wish we could reward users who post workarounds!!!!
I have been experiencing this issue a lot lately, and it's really really annoying. Do ESRI folks follow these threads?
DivisionLead
The lack of full function of these fairly basic tools for making maps is one thing that has kept our team from pushing for any expansion of our esri use, or paying for more licenses or products. Since this still has not been fixed, I doubt esri is very concerned, but it is certainly losing them some money.
