Map Frame not holding position
2713
06-12-2023 07:48 AM
TroyBungard
I need help.  I have a rogue map frame.  Arc Pro 3.1.2 - I have two layouts.  Each have two map frames.
It's laid out as a plan/profile layout.  upper frame is a map view - lower frame is a cad .dwg -
I have two layouts - only 1 with the issue.  the issue is, no matter how I set the map frame view - if I save and exit - then reopen the project.  The 2nd layout - cad frame - reverts back to a different scale and position from what was set.  if I reactivate that frame, I can only pan the view so far and it stops as if it hit a wall.  I'm assuming it reached an extent - however the extents are set to extent of all data in layers.  If I somehow manage to get it repositioned and saved or go in and manually change the extent - as soon as I let off of the extent field - the numbers revert back.  I've deleted the frame and completely recreated it - saved the project, exit out and come back - and it reverts back.  It's only on layout 2.  layout 1 seems unaffected.  I cannot for the life of me figure out what is going on with this one layout.  all other projects are fine and the other layout in this project is fine -
AubriOtis
Is your second layout a map series? Map series map frames will go back to the set position created by the map series parameters. You can zoom/pan in an activated layout to do editing, but as soon as you switch pages (or open and close the layout or project) the extent will bounce back.
Cheers,
Aubri
TroyBungard
No, it should not be a map series -
I simply click on new map frame - and insert the frame.
Initially, I had copied this layout from a previous - (as a sort of template)
After I ran into the issue - I deleted the map frame and created a new map frame - but it does the same thing.
Will try that again, and make sure it's not a series frame - (just in case).
TroyBungard
I think I may have figured out what is happening.  But I don't know how it happened, as I don't use this feature.
Right clicking on the map frame in the contents - clearing "reference scale" seems to have resolved one issue - of not being able to pan or zoom - to the original position I had set.  I don't know if it's a 'permanent' fix to it resorting back to a fixed scale and position.  Note: I've never used or set a reference scale.
