Map Extent
1507
10-01-2019 10:40 AM
ToddFagin
I am trying to do something that should be ridiculously simple. I have a project with multiple maps. I would like all the maps to be at the exact same extent and scale. I open the map properties, I click the extent tab, click the use custom extent tab, copy the the extent, and then repeat and paste the extent coordinates into a different map. Nothing happens. The map extent remains exactly as it was before. Why?
ToddFagin
It appears the work around is that once the extent is set, you have to hit the full extent button and then it adjusts.
