Manually geoprocessing and model geoprocessing having different output
1759
08-08-2023 07:05 AM
GISAdministrator8
I'm trying to create a simple model that first selects flood alert areas by area then exports the selection as a feature class:
The result however is missing all attributes:
It should look like this:
which is the output if you were to do it manually instead: select by location>right click layer>data>export features
so it uses the same geoprocessing tools (Select by Location and Feature Class To Feature Class) but the ModelBuilder version is producing data without all the attributes.
clt_cabq
Here's the issue right here, tool is deprecated and to make it work as you want, you have to use the field mapping bit to manage your output fields which is different from how the other tool works unfortunately.
Instead, use the CopyFeatures tool:
clt_cabq
GISAdministrator8
Thanks, i have also worked around the issue by first doing it manually and then dragging the tools in the geoprocessing history into the model-builder
clt_cabq
There are always multiple ways to do things - are you using an older version of Pro?
