Manage Tile Cache geoprocessing transparency problem
1728
01-22-2025 08:34 AM
MaximeDemers
I want to use the Manage Tile Cache geoprocessing with ArcGIS Pro 2.9 to create a local cache of a ecw raster imagery.
The image has four 8bits bands (rgba) the 4th band stores the transparency (0 or 255).
I have created a tiling scheme file that use the MIXED format in CompactV2 structure.
The geoprocessing is working without any problem but the cache does not have transparency at all.
Should I try with another format like PNG32?
Any other suggestions?
Thank you for your help.
MaximeDemers
I found out my error.
I had to select the map instead of the raster in the Input Data Source parameter in order to make the tool take the transparency in account.
Thank you for your help!
George_Thompson
Esri Notable Contributor
Looks like you may need to use PNG format only to have transparency. Here is some good documentation on this: https://enterprise.arcgis.com/en/server/11.3/publish-services/windows/caching-terminology.htm#ESRI_S...
--- George T.
MaximeDemers
@George_Thompson
I have made more tests since I posted and both MIXED and PNG32 are not working. Perhaps the tool does not works when the transparency is in a 4th band instead of using a nodata value as a transparent background in the raster symbology?
George_Thompson
Good question, I am not sure about that. I overlooked your note about the 4th band holding the transparency.
--- George T.
MaximeDemers
