Making a square using a point?
2469
10-21-2020 11:31 PM
hm_stella
Hello,
I am wondering if anyone knows how to make a square polygon using one point as a centroid.
 I know that the tool, graphic buffer would work as I wanted. But, is there any other tool?
Thanks all
DanPatterson
MVP Esteemed Contributor
Fishnet with one row and column and a specified cell size
Create Fishnet (Data Management)—ArcGIS Pro | Documentation
or some incarnation of Xander Bakker‌ 's
https://community.esri.com/thread/119885?commentID=449371#comment-449371
... sort of retired...
JoshuaBixby
You could also use a two-step process, Buffer followed by Minimum Bounding Geometry.
Scott_Harris
Hyun-min Joo
FYI In an upcoming release, you'll be able to use a new polygon tool called the Regular Polygon tool. The tool will allow you to set the number of sides for a polygon that you will create, preview of the functionality:
Here I set the number of sides to 4 to make a square. I can create the square centered on the point by snapping to it and dragging outward. If I had another feature nearby, I could also snap the corner of the polygon to it.
-Scott
JoshuaBixby
Scott Harris‌, will their be a corresponding geoprocessing tool, or is this just GUI?
Scott_Harris
It will be found on the Create Features pane for polygon and line feature templates. Not a GP tool.
