Make Feature Layer within a model does not add the layer
10332
20
05-13-2021 01:15 PM
Labels (2)
RandyMcGregor3
If I run Make Feature Layer as a tool, the new layer is added to my map. If I put the tool in a model and run the model ('Add to Display' is selected), The layer never appears.
If I open the model and run it, the layer is added to the map, but they are in an awkward group called 'ModelBuilder' and have a prefix I don't want them to have.
I would like to run the model as a tool and when I do that, nothing gets added to the map.
Is there something I can do to make the created layers visible?
Thank you,
Randy McGregor
JayantaPoddar
I believe it is by design, that a geoprocessing tool will not "add to display" when the multiple outputs are expected for a single variable. Split by Attributes GP tool is an example.
You could add a "Save to Layer File", save the layers inside a predefined workspace. Then Add the layers using Add Data option.
Think Location
JayantaPoddar
Please set the output as a Model Parameter as well.
As per Run a model
Note:
After the model tool runs successfully, only model outputs set as model parameters are added to the map.
Think Location
RandyMcGregor3
Excellent advice. I appreciate it. I have found it works maddeningly inconsistently, though. The model has an iterator, and I think that may introduce a wrinkle.
I want to create a  selection layer for each value in a field. Once, the first value appeared then disappeared when the model was done. Another time, only the final value appeared, but it did stay.
I fear the iterator may introduce complications to this?
JayantaPoddar
Good to know. Could you also try using inline substitution for the output layer name?
Think Location
RandyMcGregor3
Like this?
Doesn't work :(. I did remove the iterator and the one output layer was added, so I think I've hit a snag with the iterator. Thank you very much for your help here!
Randy McGregor
RandyMcGregor3
I added a 'Save to Layer File' tool and that does create a *.lyrx file for each unique value. The model will not add those into the map either, but it does create something I can see and work with after the model has run.
Loading feature layers created within a model or a script into the TOC has always been difficult. I have an old python script that does it and it's got a LOT of steps.
JayantaPoddar
Don't rename the Value. Rename the output layer in Make Feature Layer tool.
Think Location
RandyMcGregor3
I appreciate your willingness to work through this. This is pretty much what I have been doing. I can get them to add to the TOC from within model in a 'ModelBuilder' group like you show here, when I open the model and run it, but not when run as a tool.
RandyMcGregor3
If I run the iterator first, so that it is 'stuck' on the final value it calculated and only processes that one, it will add the inputs to the map. If I reset the iterator so that it cycles through all the values, it will not add the layers to the map.
JayantaPoddar
Think Location
