List Layouts: how to find out the Layout Number
2628
11-17-2023 02:50 AM
Labels (3)
IlkaIllers1
I want to export a map series as jpgs and am trying to write a script. However, I am stuck in how to "call" the correct layout. There are 9 layouts in the aprx, however, there used to be more that were deleted. I am trying to find the right one by trial and error going through numbers. This is the code:
aprx = arcpy.mp.ArcGISProject(r"path.aprx")
lyt = aprx.listLayouts()[0]
print(lyt.name)
Is there a way to find out the number/position of the layout? I was thinking of something like that:
for lyt in aprx.listLayouts():
    print(lyt.name)
    print(lyt.???)
Is there any property I can put in there to find out which position it has?
Thanks!
JeffBarrette
Hello @IlkaIllers1 .  Position should not matter.  They are sorted in alphabetical order in the Catalog pane but you should reference the layout by name.
for example, lyt = aprx.listLayouts(wildcard='Some Layout Name')[0]
Because it is a list, you still need to specify an index number to return a Layout object from the list but if your wildcard value is unique enough, there should be only one element in the list (with index=0)
Jeff - Layout and arcpy.mp teams
JeffBarrette
IlkaIllers1
Hi, thanks for your answer. It kept telling me the list index was out of range when it was set to 0...
JeffBarrette
If you use a wildcard value, you must match the layout name exactly.  It is case sensitive.  You can also use an * in the wildcard.  For example if I have a layout called 'Great Lakes' I can so stuff like:
lyt = p.listLayouts('Great*)[0]
lyt = p.listLayouts('*akes')[0]
lyt = p.listLayouts('*eat*')[0]
IlkaIllers1
thanks. I copied the name from the layout directly, so it shouldn't be an issue. I think this might be connected to several issues I have been having where content can't be renamed/is renamed but is then having issues/reappears after being deleted and similar things. I tried again with a fresh aprx and it worked fine, so I believe this must be related to these issues (I did rename the layout just before trying the arcpy export). Thank you!
