Link another map to the current map series index feature
840
12-06-2023 07:38 AM
ZacharyForsythe
Hello! I'm attempting to create a map series layout. On my layout, I have one map frame that is being used as the base for the map series (where its drawing its index variable from, etc.) In the map series settings for the map frame, I'm given the option to clip the map frame to the index feature. This allows me to go into the Map and limit which layers can be clipped. This works great because I'm trying to limit the display of points to certain country boundaries.
My problem arises when I'm trying to do the same thing for another map that I've created inorder to highlight another layer on the map. With this other map frame I can't clip the boundaries to the index feature (the county boundaries). Is there a way to clip another map frame to the index feature of the map series?
If so, help would be appreciated. Thank you.
