License Manager with ArcGIS PRO
6344
05-07-2015 10:04 AM
FranciscoAcosta_Bazán
Anyone knows details?:
..In an enterprise environment, ArcGIS License Manager can also host and distribute enterprise single-use licenses or ArcGIS Pro named user licenses via a Portal for ArcGIS instance.
Tags (3)
by Anonymous User
Not applicable
If your organization uses Portal for ArcGIS rather than ArcGIS Online, you can download an ArcGIS Pro license entitlement file from My Esri, import this to the License Manager, and then export a file to Portal for ArcGIS. Once the ArcGIS Pro entitlements are in the Portal, the Administrator can manage them just as is done in ArcGIS Online.
by Anonymous User
Not applicable
BryanPrice
Royce,
 I am on week 3 of working with ESRI support (on & off) on an issue of using Portal Named Users / License Admin through firewall to public internet ArcPro users. and continue running into brick wall. do you have any experiance with this method that may shine some light? Ill reply with details if you have
George_Thompson
Esri Notable Contributor
@BryanPrice This is a very old post, you may want to create a new post for better visibility.
Are your external ArcGIS Pro users trying to access the LM (concurrent) or Portal (Named User) for the license?
--- George T.
BryanPrice
Portal Named Users
- Bryan P
