Legend in Argis Pro
1706
07-15-2019 10:37 AM
by Anonymous User
Not applicable
Is it possible to only see legend items that are shown within a layout frame? If not, I am submitting this as an ArcGIS Pro Idea.
Thanks
Tags (1)
RachelSears
Hello Heath,
In the Legend Properties box, click the "Show Properties" button under Legend items. Check the box that says "Only show features visible in the map extent."
Hope this helps!
- Rachel
by Anonymous User
Not applicable
Rachel
I don't see that option. I am running 2.4 now.
Thanks for the super quick response.
Heath
by Anonymous User
Not applicable
Rachel, I should also let you know that my data is from a feature service. Not sure if that makes a difference.
Thanks
RachelSears
Hello Heath,
Thank you for providing a screenshot. It is odd that you do not have any of the options in the Feature Display Options category. The option was implemented in version 1.4 of ArcGIS Pro, so I am unsure why you are not seeing it if you are using version 2.4. I recommend contacting Technical Support and opening a case with this issue.
https://support.esri.com/en/contact-tech-support
- Rachel
