Layout select tool annoyance
757
05-24-2023 09:45 AM
TonyAlmeida
MVP Regular Contributor
Whenever I am in the layout view and want to edit multiple text objects, I have to constantly click on the select tool every time I want to edit a text object. THIS IS SUPER ANNOYING. Is there a way to keep the Select tool active until you select a different tool?
wayfaringrob
Honored Contributor
@TonyAlmeida  are you running into this when adding graphics? i.e., does it revert to a drawing tool, like one of those on the Insert tab > graphics and text group? If so, unchecking 'Keep last tool active' should help until this is fixed.
Here are the details on the upcoming fix, looks like in Pro 3.2:
