Layout Pixels Drop
2464
04-06-2023 03:19 PM
AbdulWahab
Hello everyone,
I am Abdul Wahab studying MSc in Environmental Management at Kingston University. I am working on the assignment where we had to make a map. I was trying to show an open space area where possible Solar Panels can be installed within a London Borough. I need suggestions on how can Improve/show my Solar panels which I have drawn with a Point shape file.
The problem is the borough map is big and my panel area is very small, it is not looking nice at all. And looks like very basic work done. I have added a graph from Excel on the map legend which is showing the temperature of the area taken from the nearest weather station.
When I exported the map layout its pixels has been dropped.
JesseCloutier
Esri Community Manager
Thanks for bringing your question to Esri Community, @AbdulWahab. We're glad to have you here!
Because your post is primarily a question, I'd like to help get your post moved over to one of our conversation boards where it's more likely to be seen and responded to by members who can help. Which ArcGIS product are you using?
Jesse Cloutier
Community Manager, Engagement & Content
AbdulWahab
I am using ArcGIS Pro version recent version.
JesseCloutier
Thanks for following up with those details, @AbdulWahab. I've moved your Post to the ArcGIS Pro Questions Board. All the best!
Jesse Cloutier
DavidPike
MVP Notable Contributor
Might be a case for an inset map.  Google inset maps or multiple maps in layout and I think there's several videos.
Might be best to have your main map as your solar panels and a smaller map to identify the borough.
AbdulWahab
Hi, thank you for pointing that out. I am a newbie,  but I will definitely check out the terms you have identified and see if that fixes the issue.
