Layout name cannot contain quotes anymore?
1575
12-16-2021 02:58 PM
wayfaringrob
Honored Contributor
I'm wondering if this was an intentional change or a bug I'm experiencing - I went to rename an existing layout (adding " - OLD" to the end) and got this error:
The name had quotes before, and as you can see, so do several other layouts. Is this a new limitation, or a bug? I imagine quotes might cause some issues with some scripting languages, but the fact that we were able to use quotes in the past doesn't make sense then.
DanPatterson
MVP Esteemed Contributor
2.9 Pro, Catalog Pane, no problem for me
... sort of retired...
wayfaringrob
Honored Contributor
That is so strange
DanPatterson
51 in. x 42 in.
until you get someone from Tech Support to test your data.
It isn't even a standard paper size is it?
Paper Sizes - Huge list: ANSI, International, Envelopes, Business Cards... (printhandbook.com)
wayfaringrob
Honored Contributor
No, but I can't imagine that that's the problem.
DanPatterson
I wasn't suggesting that, I was just trying to find a simpler substitute,... like "legal", "A4" etc.
"in." is the workaround for now, contact Tech Support since I can't replicate it
