Layers not editable ArcGISPRO
4477
05-21-2025 12:30 PM
IntisarTyne
Hello, I was using Arc MAPs for sometime. Recently I had to make a transition to Arc GIS PRO. I am working in a building project and using the building map to input observational data by using Arc GIS PRo. When I imported my map with several layers (which I created in Arc Map for 1 year) in Arc GIS pro all the layers became uneditable. Now I can not add/ move or remove data points in Arc GIS pro. Any suggestions to help me?
Intisar
DavidPike
MVP Notable Contributor
What's the data source/location and data type for these features?  Any topologies? Can you share any screenshots or more info?
There could be licensing issues e.g. some examples could be that a Basic Pro license user couldn't edit SDE database data, or a Geometric Network wouldn't be editable in Pro in any situation.
Teresa-AZ
Hi Intisar,
I migrated from ArcMap to ArcGIS Pro back in the v2.4 days (many years ago) and I took the Esri course on doing this migration and I remember the "Edit" button is not always ON or OFF in the ArcGIS Pro environment so maybe check out this:  https://pro.arcgis.com/en/pro-app/latest/help/editing/enable-and-disable-editing.htm
Best of luck!
Teresa-AZ
MErikReedAugusta
MVP Regular Contributor
The first thing I would check are the Selection & Editing tabs on the Contents pane.  By default, they show up on the left-hand side when you're looking at a map, unless you've moved them.
Circled in A are the two tabs in question.  The blue-shaded one is the selection tab; uncheck things to make them unselectable in the map, or vice versa.
The one with the pencil is the edit tab.  Same thing: Unchecked means I can't edit it, and checked means I can.  But also, notice those exclamation points circled at C.  Those mean I don't have permission to edit those data.  That's something I pulled from our organization's SDE that's controlled by a different department; I have read-only access to them.
If you were able to edit in Desktop, but not in Pro, I would predict the problem is likely just them being unchecked for some reason.  If you are getting the exclamation points, though, I would talk to whomever manages the database you're accessing.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
DanPatterson
MVP Esteemed Contributor
Did you move/relocate the source data? Is it stored locally?
... sort of retired...
