Layer visualization issue
1175
09-15-2021 01:11 PM
MarcoQuilca
I can visualize a layer and all its content (lines, points, tags) in the Attribute Table. However, when double clicking on any of its content I can not visualize them. It takes me to the right place (pan to) where it supposed to be in the map but there is nothing there. It seems to be hiden or something else. Could you please help me out.
David_Brooks
MVP Regular Contributor
@MarcoQuilca can you share some screenshots so we can get a better understanding of what you're dealing with?
What is your symbology setting?
What coordinate systems are you working with?
Do you have any display settings for different zoom levels?
What is the type of data? Shapefiles, feature classes, web service? Etc
David
..Maps with no limits..
MarcoQuilca
Hi david thanks for your kind help. I would really appreciate  if you can come up with a solution.
Here are some pictures  and the informationif you requested
Coordinate system WGS 1984 auxiliary sphere
I have attached all project files in a zip file for you to be able to open the project
2021-09-16 16_41_42-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - FLOWLINES_TARAPOA - ArcGIS Pro.png
All lines belong to the same level which is on the ground
2021-09-16 16_42_54-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - FLOWLINES_TARAPOA - ArcGIS Pro.png
2021-09-16 16_13_32-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - TARAPOA BLOCK_FLOWLINES _MAPPING_2021 - .png
Here is the project I´ve been working on. I have drawn some features the line tool, those represent piping flowlines.As you can see I also calculate all pipeline´s lenght in meters using calculate geometry option
2021-09-16 16_15_09-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - FLOWLINES_TARAPOA - ArcGIS Pro.png
As you can see I have my lines in the attributes table. It supposed when double cliking on any of them, two acctions follow to it. 1. It takes you to the place it was drafted at   2. Then the line will show up.
2021-09-16 16_16_08-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - TARAPOA BLOCK_FLOWLINES _MAPPING_2021 - .png
In this picture. It supposed to show up a line between **bleep** 1 and **bleep** 4 which are taged points in the map however, it doesnt show up
2021-09-16 16_17_35-ANDESPETROLEUM_FLOWLINES_MAPPING_2021 - TARAPOA BLOCK_FLOWLINES _MAPPING_2021 - .png
