Layer to KML 'Name' missing when using python
6215
11
07-08-2018 07:41 PM
MarkHansen1
I'm exporting a point features to kml via a python script but the generated kml has no 'Name'  information.  i.e. when you expand the list, every point says "[no name]".  All other data is correct.
There is a 'Name' field in the attribute table.  It is the first field after the Object ID and geometry field.
simplified code:
arcpy.management.MakeFeatureLayer(InFc, OutLyr, None, None, None)
OutKmzPath = ProjectPath + "out.kmz"
arcpy.conversion.LayerToKML(OutLyr, OutKmzPath, 0, "NO_COMPOSITE", "DEFAULT", 1024, 96, "ABSOLUTE")
but, if i do the same from within ArcGIS Pro (v2.2) the generated kml has the name field correctly populated.
Is there another step to get the kml Name field to populate when running in a script?
DanPatterson_Retired
Can you ensure that you are using Pro's arcpy?
Also... although they should be technically equal, try
arcpy.MakeFeatureLayer_management
and dump the None entries, since they aren't needed
MarkHansen1
Hi Dan,
Python v3.6.5.  I'm using Idle - right-click the py file, choose "Edit with IDLE (ArcGIS Pro)".
tried arcpy.MakeFeatureLayer_management but no joy.
yeah... the code still needs a lot of clean-up.
Thanks
I don't see anything obvious in your code though.  Try it within Pro's IDE so that Pro is also open.. I just have a feeling I have seen this before
MarkHansen1
running it within the IDE works
Now to find the reason... which is why I asked about Pro's arcpy... Do you have ArcMap also installed?
I know it uses python 2.7, but I used python 3.x when I used arcmap (just a matter of direction to arcpy)
Addendum
Are there any spaces in the names of the input or output files?  Pro doesn't like them (which is good) and that behaviour separates map from pro... although I haven't fully investigated yet
Addendum 2
Check your installation of arcpy …. from whatever environment
import arcpy
arcpy.__file__  # mine is installed in c:\arcgispro... not the normal install
'C:\\ArcGISPro\\Resources\\ArcPy\\arcpy\\__init__.py'
arcpy.GetInstallInfo()
{'InstallDir': 'c:\\arcgispro\\',
 'Installer': 'dan_p',
 'ProductName': 'ArcGISPro',
 'Version': '2.2',
 'SourceDir': 'C:\\Computer\\ArcGISPro_2_2\\ArcGISPro\\',  # ---- msi file
 'InstallType': 'N/A',
 'BuildNumber': '12813',
 'InstallDate': '2018-07-05',
 'InstallTime': '23:34:14',
 'SPNumber': 'N/A',
 'SPBuild': 'N/A'}
MarkHansen1
ArcMap 10.6 is installed.  I started this project using map but switched to Pro because of this problem with the surface difference tool https://community.esri.com/message/767562-using-a-las-dataset-with-the-surface-difference-tool.
No spaces in the input or output data files.
import arcpy
arcpy.__file__
Out[2]: 'C:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy\\arcpy\\__init__.py'
Out[3]:
{'InstallDir': 'c:\\program files\\arcgis\\pro\\',
 'Installer': 'Mark.Hansen',
 'Version': '2.2',
 'SourceDir': 'C:\\Users\\mark.hansen\\AppData\\Local\\Microsoft\\Windows\\INetCache\\ArcGISUpdate\\ArcGISPro\\esrisoftware.esri.com\\',
 'InstallDate': '27/06/2018',
 'InstallTime': '9:43:07',
 'SPNumber': 'N/A',
 'SPBuild': 'N/A'}
JoshuaBixby
MVP Esteemed Contributor
My hunch is the issue revolves around a KML Placemark name being "name."  Just as a test, if you rename the "name" field to "name1", does it work in the script?
MarkHansen1
Hi Joshua,
'name1' makes no difference.
I first suspected it was something to do with the 'name' field.  I saw this post (https://gis.stackexchange.com/questions/16934/how-is-the-default-label-field-chosen-by-arcmap) and started playing with variations of name/NAME/Name.  My name field is a string.
It works fine and the name is populated if you run it within the ArcPro python IDE or with the geoprocessing tools.
Because of this I suspect it has something to do with ArcPro being open and the layer is added to a map first and then exported to kml.
I have been playing with this some more and I am guessing there is some little behind-the-scenes extra that automatically sets the default label when you add the layer to a map, then when you run the layer-to-kml it picks that default label and populates the name field in the kml.  When I do this in ArcPro and check the label, it has already selected the field called 'name'.  As a test I reordered the fields in the table and put the name field last then added to the map - the 'name' field was still selected by default.
I think that because my script doesn't run inside ArcPro and never adds to a map, the default label does not get set on the layer, therefore no name in the kml.
So, is there a way to set the default field in python?
Nothing that I have found from the links, but... in desperation, perhaps you need to add
Save To Layer File—Data Management toolbox | ArcGIS Desktop
after the makefeaturelayer to see if it persists... and if you really need to… Delete_management it after
