Layer File (lyrx) in Project Changes Source Path when Project is Copied Issue.
814
09-09-2024 08:47 AM
PeteJordan
  I have a a default project that I use to copy over each time I want a new fresh start.  Reason I do this is I have all the layers I want set up as well as all the folders and notes in the project location to make it much easier.  There is a layer file that points to a shapefile in a set location that I want to keep there.
  When I copy the project, everything links just fine (all but the layer file are on SDE), all except the one layer file.  I look at the source link and it's always appending the new folder location to the existing path and why it breaks.  I want to keep this source file in the same location as it often gets updated.  Everytime I export the layer to a *.lyrx, I don't see any option to keep the file source path relative at all.
  Is there anyway to prevent this from happening to the layer file as I laways have to relink the broken link?
Original source I want to keep for the shapefile the layer links to:
Spoiler
New source layer that appends the new name which I don't want when copying the project over:
Spoiler
