las projection
835
10-13-2022 01:04 PM
by Anonymous User
Not applicable
Hello,
I have lidar data that was obtained in a projection of UTM83 Zone 15 in meters. I am trying to change the projection to a local coordinate system. Is there any way to complete this?
Erika_ess
Hello, have you created a LAS Dataset? You can search for the Create LAS Dataset tool on pro, select your LAS file, and there's a drop down menu for the coordinate system there. In the contents pane on Pro, you can edit the coordinate system for a map or scene.
