LAS FILES- Unable to read Projection Information
968
10-24-2023 01:07 PM
RichardVincent1
I have LAS files with the SRS Defined as GCS_WGS84/VCS:EGM96 Geoid  (EPSG 4326+5733)
When I loa into my project I get a Error "Unknown Coordinate System) - I have checked the las files using LASTOOLS and the records look correct ( the lasinfo tool reads the data correctly )
I can use Create LAS dataset to bulk process and add the same info again it then loads correctly
Question - is there a known issues with reading  LAS  LASF_Projection records ?
