Land Cover Shapefile Data???
10437
16
03-08-2024 08:14 AM
AvaFarouche
Hi, all,
Does anyone remember using a National Land Cover Dataset in the form of a shapefile or layer, as opposed to an image file?  There are some gorgeous imagery layers for Land Cover now - but I can't query them.
I used to have a shapefile layer for land cover, and I could separate out different categories, calculate areas, conduct queries to see how different categories intersect with other layers, etc.
I cannot find anything of the kind available anymore. Does anyone remember what I'm talking about or know where something like this is available now?
Thank you!!!
kronezone
What is the place you found that allows you to export shapefiles by state?
AvaFarouche
Darn. I keep breaking it down into smaller and smaller sections to export, and I keep getting an error that the raster exceeds the size limitations. The smallest size so far I have chosen is Kentucky, but I need this to cover several states together, at least, so if I have to break it down smaller than that it's really not practical. So..... I'm not sure there is a solution to this. Break it down into counties, and piece 20+ pieces together for each state, and then piece 8 of those together? I guess I could if I have to ..
Ed_
by MVP Regular Contributor
yes, there's a constraint on the raster output size, you would have to break them into counties and then merge them together in the end using the Append tool.
Question | Analyze | Visualize
SteveCole
Honored Contributor
You can also bypass the Living Atlas and go here and download the data for whatever years you're interested in.
AvaFarouche
Thanks, Steve. Yes, I already downloaded several files from that site. I still have the same problem of converting to shapefile. Everything I've found on there is raster.
by Anonymous User
Not applicable
AvaFarouche
Hi, there. The reason is because I'm basically self-taught and I learn by googling and posting here as a last resort. I have used shapefiles for these in the past so that's what I was looking for. But thanks for bringing it up, I'll look into it.
