Joining Tables NULL?
1567
11-25-2022 10:18 AM
SaulCardona
I'm attempting to join two tables by NAME (per the instructions of the assignment). But when I do join them, the data of the second table appears as NULL. I don't understand what I'm doing incorrectly.
Tags (4)
SaulCardona
Update, I did find that one state did appear in the joined table, the other still appear as Null
DanPatterson
MVP Esteemed Contributor
There was a warning (yellow ! mark).  What did it say?
... sort of retired...
BarryNorthey
Click the Validate Join button and check the message. See also the Add Join help for examples.
It is unlikely to be the problem but text in text fields can have invisible trailing (and leading) blank spaces. I have found this to be a problem on more than one occasion, even from "reliable" data sources. The following text string images look to be the same but the lower one has a trailing blank, which can be seen by clicking the mouse at the end of the text string. ArcGIS Pro sees them as different and no match will be made.
