Join table to feature class to output feature class (with shape information)
3721
09-26-2023 07:58 AM
Jay_Gregory
Is there an easy way in Pro (i.e. without Python) if I have a feature class and a table, and I want to join the SHAPE field from the feature class to the table, joining on a common attribute field.
The end result I'd like is to convert the table into a feature class, based on a shared column from a reference feature class.
For example, lets say I have a table with a list of facility ids.  And then I have a feature class with facility ids and their location.  How do I get the location information from my feature class to my table?
Tags (3)
DanPatterson
MVP Esteemed Contributor
Add Geometry Attributes to get the X, Y coordinates into the featureclass's table,
Add Geometry Attributes (Data Management)—ArcGIS Pro | Documentation
Join the featureclass over to the table
Join Field (Data Management)—ArcGIS Pro | Documentation
then make a featureclass out of it using
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
and make sure you specify the coordinate system
... sort of retired...
