join dataframe with layer
2060
10-20-2021 07:29 PM
hammurabisevilla
Hello everybody:
I am trying to join a pandas dataframe with a layer in my project using and id column and finally display it in my map project .
I am looking for some notebook or scripts examples, do you have a reference solution for that problem?
Thanks in advance
DanPatterson
If you can get it to a numpy array, arcpy.da has ExtendTable which essentially does a join.  Otherwise convert it to a geodatabase table if you can (arcpy.da.NumPyArrayToTable)
Some examples exist
arcpy - Join Pandas Dataframe to Shapefile? - Geographic Information Systems Stack Exchange
... sort of retired...
hammurabisevilla
Thank you Dan for your reply, that answer makes me to ask again, if that solution is sort of retired, would you mind take me to the most updated solution?
how do you solve that? that's because I am QGis user and that is the way I use to do it...
thank you again.
DanPatterson
is my signature.  The suggestions are not 😉
